warrior leaking gas
Old Jun 2, 2010 | 07:28 PM
m16a2's Avatar
Default warrior leaking gas
My warrior is leaking gas from the carb drain line. The drain screw is tight, ( i havent played with it for a few months) yet it leaks from the drain line attached to the bottom of the carb. It wasnt leaking before, and all of a sudden, its leaking like a siv. thanks
Old Jun 2, 2010 | 09:22 PM
91Warrior357's Avatar
hmm the float must be sticking causing fuel to keep going into the bowl and it comes out of the overflow tube, it either needs to be cleaned or the float pin isnt on right and is binding on the sides of the carb or something.
Old Jun 2, 2010 | 09:25 PM
Scooter86's Avatar
Knows Old ATV Questions!
Something is causing to much fuel to flow into the float bowl. Could be sticking floats, could be old gas varnish/gunk gumming up the needle valve, or even the rubber portion of the needle valve itself has gotten hard over time therefore not sealing. Pull the bowl off, carefully clean all the varnish out of there and see if that solves the problem first.
Old Jun 3, 2010 | 02:26 PM
95wolv's Avatar
Most likely your needle and seat is worn,my 95 Wolverine has the same carb, and I had the gas leak same as you, tried adj. float, cleaning, etc, no luck. had dealer check seal of needle and seat, was leaking by, new needle and seat fixed it, hasnt leaked in years.
Old Jun 3, 2010 | 07:05 PM
m16a2's Avatar
so you guys are saying, even if the drain plug screw is tight, it may still leak due to float problems? I know when I first got it, the float was stuck because it wasnt getting any fuel.
Old Jun 3, 2010 | 10:06 PM
Scooter86's Avatar
Exactly. If the floats stick up high, or the valve seal isn't working, it will leak out the overflow.
Old Jun 6, 2010 | 06:07 PM
m16a2's Avatar
fixed. that was the problem- the float was sticking. I sparyed a ton of carb cleaner in it, and that solved the problem. Runs perfect now. thanks
Old Oct 19, 2020 | 12:36 AM
GOODVIBES316's Avatar
Default Help
Where exactly did you spray your carb cleaner in,am currently in the same situation you where in man.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
wrencher82
Sep 24, 2015 03:39 PM
