2003 660 wont start
Im looking into this project quad & the owner says it got good compression the carbs leak, but the engine wont start.. it spins over just fine, but I am unsure if it has a spark or not.... any suggestion about what the problem might be ?
i would see if it has spark before buying it. a new CDI box can go for up to 400$, and a new coil, and stator isnt cheap either. check for spark, if it has spark try to run it enough with the headlights on to tell if it charges. if it does this, buy it. several things can cause it not to start though. the carb sucking air/leaking would make it hard/if it would start at all. i'll just leave with this. if it has spark, it can be fixed. lol
come to find out after running the vin, its a 2001 model, so now i have tranny issues to worry about, on the bright side i found somebody who will change out the starter clutch for $100 , no i just need to fix the oil leak,starter solenoid & the carburetors
