yamaha carb problem
Old Jun 24, 2010 | 12:46 PM
armyguy_88's Avatar
Default yamaha carb problem
i have a 1979 yamaha mx 100f i am restoring and im almost done i had it running and it ran a little rough so i took the carb off and cleaned it and tried it again and it ran good the next day i went out and tried to start it again and it started and died now it wont start. i have good spark wat can i do to get it to start.
Old Dec 1, 2010 | 01:34 PM
budd68's Avatar
Cool
hello; i would start by makeing sure your fuel tank is clean.then check the float hight in the carb is set right.also clean all jets and pasages in the carb body and blow them out good with air.
Old Dec 5, 2010 | 07:46 PM
team_realtree's Avatar
X2 on checking float height. Mine was flooding so it would run nice when it was cold and had a rich mixture then it would die. It takes about all off a half an hour to get the float within spec and now i couldnt get mine to stall if i tried.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
njrider64
Jul 4, 2017 01:40 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
