whats the flashing reverse light mean?
Old Jul 2, 2010 | 10:36 PM
benks's Avatar
Default whats the flashing reverse light mean?
i have an 07 wolverine, and i couldnt really find an answer in the owners manual but it only happens when i start the atv and let it warm up with the choke on, thanks
Old Jul 3, 2010 | 05:48 AM
Kodiak450_06's Avatar
Possible bad fuse. Check the fuses located under the seat. This happened to me awhile back and I had a bad fuse, so I replaced the fuse and the flashing went away.
Old Jul 3, 2010 | 09:27 AM
benks's Avatar
ok, ill check my fuses, its just weird because it only happens when i warm it up with the choke on ( in park), and when its in reverse the light stays lit, someone told me this could be a possible overheating sign?
Old Jul 3, 2010 | 04:21 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Flashing Light
I have experienced the same thing on my 08 Big Bear...light flashes when I have left it warming up with choke on...all I could figure was that it was a sign that the choke is on for too long. Once I shut the choke off and let it idle down and move the quad the light returns to normal. Never really concerned me I guess just watch how long you let it run with choke on!
Mudslinger2
Old Jul 11, 2010 | 12:25 AM
kfx_rider's Avatar
All wolverines do it. Some other ATVs probably do it to. It means that the rev limiter has been reached. Basically it's telling you to stop reving the engine so much/high in neutral.
Old Jul 11, 2010 | 01:23 PM
benks's Avatar
ok, sounds like i just have to turn down the idle speed, thanks guys
Old Jul 11, 2010 | 10:51 PM
kfx_rider's Avatar
Does it blink when in idle? Or does it blink when you rev the engine? If it is blinking in idle then you probably have the choke on which is no big deal just take the choke down a little. If the choke is not on then yes, you probably should turn down the idle speed just a little.
Old Jul 22, 2010 | 11:48 AM
Butch450's Avatar
Flashing reverse is a speed sensor problem on midsize yamahas. If you leave choke on when warm it will do it also and you just have to turn off and restart and the light goes out. If it flashes when not idleing and diff lock and rev overide is working then the sensor is probrably bad.
SyTye
Sep 11, 2015 02:45 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
