Question on sand tires
Old Jul 22, 2010 | 10:49 PM
Sapper79's Avatar
Default Question on sand tires
Looking to get opinions reference tire sizes. I currently run 22 12x10 haulers on my Raptor 700. I opted for the 22's because I heard from a guy, that had a friend, that knew a guy, who said, 'run the largest size tire your machine can handle for best performance'. It made since and all the really bad***** machines seem to be using the larger rear tires. Had a conversation at the dunes recently with a guy who explained a smaller, say 20 12x8, tire works better for better tire spin to move the sand. That also made since. Anyone with any ideas, theory's or suggestions in this area. Thanks in advance.
Old Jul 23, 2010 | 09:39 PM
Terrellster's Avatar
Originally Posted by Sapper79
Looking to get opinions reference tire sizes. I currently run 22 12x10 haulers on my Raptor 700. I opted for the 22's because I heard from a guy, that had a friend, that knew a guy, who said, 'run the largest size tire your machine can handle for best performance'. It made since and all the really bad********* machines seem to be using the larger rear tires. Had a conversation at the dunes recently with a guy who explained a smaller, say 20 12x8, tire works better for better tire spin to move the sand. That also made since. Anyone with any ideas, theory's or suggestions in this area. Thanks in advance.
If you do not change anything else, Tire size alone will not give you any better performance..... Smaller tires will give you more torque in the low end, Making wheelies and such things easy..... but you sacrifice top end speed....
Larger tires will give higher top end but you lose a lot of lower end torque,....
You can feasibly change to larger tires and get similar to factory performance, by adding a larger rear sprocket by a tooth or two.... or even dropping a tooth on the front sprocket..... Go the other direction with the smaller tires and gears.....
Old Jul 25, 2010 | 09:58 PM
bigned1904's Avatar
tell him 22s float better , for general riding with some dragging 22s imo are the best for a big quad like a raptor. 25s if all u do is race. my fav size is 22x11x8.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
nachop
Feb 14, 2018 06:57 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
