97 blaster
Old Apr 4, 2011 | 06:22 PM
srsblaster's Avatar
Default 97 blaster
can anyone please tell me how to remove a back axle on a 97 blaster does the sprocket thread off? anything else i should know? thanks for your help
Old Apr 4, 2011 | 07:45 PM
HMT Racing's Avatar
No it is splined and probably very rusted and stuck. Good luck I had to cut my last one off
Old Apr 4, 2011 | 09:22 PM
Terrellster's Avatar
I would recommend a 50/50 solution of ATF (yeah,... Automatic Transmission Fluid) and acetone,.... It will beat any penetrant you can buy, by at least double the ability (Usually 60% or better penetration and lubrication on "stuck" stuff) the concoction will separate when left standing as it doesn't combine on a molecular level..... It's more of an emulsion. Mix it up by shaking it thoroughly and spray or pour it onto the rusty connection and let it sit for about an hour (Get it really wet). Then protect the axle end threads and knock the axle through the sprocket hub. This is assuming you have already removed the two jam nuts from the axle also. generally speaking, I use a heavy piece of thick wood and "drop" the axle left end onto it from about a foot in the air,.... guiding the assembly to make sure it hits where i want it, and doesn't damage the axle end. This can take some time, so be patient.
Likelihood is, the sprocket hub is not the only stuck part. I suspect the bearing and spacers in the rear axle hub are corroded onto the axle also. Still saturate the whole hub in the above concoction and give it some time to do it's stuff.... You'll be fine.
Old Apr 4, 2011 | 10:29 PM
srsblaster's Avatar
Hey thanks for the help I'll try those tips tomorrow. I'll let you know.
Thanks again
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
