Warrior bogs under constand high speed
My warrior is a 2000 the other day I noticed while in 4th 5th 6th gear if I held it at a constant high RPM for about 15-30 seconds it would begin to bog to the point where it was start to fall on its face which lead me to believe it was a fueling Issue. Checked the floats cleaned the carb, blew out all the hoses, cleaned the petcock on the tank, new fuel.. The accelerator Pump was stuck fixed that.. And it still does the same exact thing.. Any Ideas? Iv been running the same jetting now for almost 3 years so I don't believe that is the case because it just started to do it.
