96 350 Warrior Seized
Old Apr 24, 2011 | 08:08 PM
katt68's Avatar
Default 96 350 Warrior Seized
My sons warrior started up today.....ran for a moment then a grinding sound and then shut off and now can pull it over.
what should i check before ripping into the engine?
any known issues?
could it be, piston,crank, valves?
was running perfectly prior to this....
Old Apr 24, 2011 | 08:21 PM
m.jones101604's Avatar
don't know much about the worrior's I would start just pulling the valve cover check you valve's make sure all stems are straight and even. then if nothing pull stator and check lower end bearing and timing chain
Old Apr 24, 2011 | 08:23 PM
just thinking that because if chain jumped time that could have been grinding noise but like I said don't know much about the internals on worriors
Old Apr 25, 2011 | 04:47 PM
ryder133's Avatar
Did you remember to put oil in it? ;D
Reactant
Mar 30, 2022 02:08 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
