05 Kodiak 450 - Fuel in oil - thoughts??
Old May 15, 2011 | 06:56 PM
Lightman's Avatar
Default 05 Kodiak 450 - Fuel in oil - thoughts??
Hey guys. Today was rainy so I decided to do a little spring maintenance on the Kodiak. I changed the front and rear diff fluid, drained-flushed-filled the coolant, and cleaned-reoiled the air filter. Whew! The oil was only changed back in october and hasn't had much use, so I figured that didn't need changing..but I thought I'd check it. Boy, it was WAY overfilled...something was up because I am too careful to not overfill when changing. I took a sniff and it definitely smells gassy...and not Al Roker gassy, BP gassy... Any thoughts as to where it's coming from or what to look for? I noticed recently also that when leaving it parked in my garage with the fuel petcock on reserve, there was a strong gas fume smell. I'm not sure if they are related or not, but the gas in the oil is obviously the biggest concern. Thoughts on what it might be or what to check first much appreciated.
Old May 16, 2011 | 10:21 PM
vangasman's Avatar
Sounds like the fuel is leaking through your carb and washing down the cylinder walls to the crankcase. Turn the fuel off and probably rebuild the carb.
Old Jun 2, 2011 | 08:30 PM
lightninboy's Avatar
Yeah, I always turn off the fuel valve when I am not using it.
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
