banshee lights on a blaster??
Old Oct 6, 2011 | 08:24 PM
TacticalRedneckofKentucky's Avatar
Lightbulb banshee lights on a blaster??
ive came up with an idea here... yeah i know, hard to beleive...
but anyway:
does anybody know , think, if its possibal to hook up banshee lights without drilling wouldn't know because i dont have a banshee and never had a chance to look up close..
Old Oct 7, 2011 | 08:27 AM
HMT Racing's Avatar
Up sure, you could make a bracket to come off the upper shock mount, don't know if the electrical system could handle it though???
Old Oct 7, 2011 | 11:27 PM
JLsparky7's Avatar
Maybe try just one light at first? But its possible.
Old Oct 8, 2011 | 11:59 AM
Jaster94's Avatar
what's so different about the electrical load? can the stator not handle it? or would he need to upgrade other electrical components?
Old Oct 8, 2011 | 01:34 PM
JLsparky7's Avatar
The stator on a blaster is much smaller then a banshee. Not sure on the power output difference.
Old Oct 8, 2011 | 02:38 PM
Jaster94's Avatar
thanks! worked on 2 blasters before, but i've never been around a banshee. hmmmm..... thanks for the info.
Old Oct 8, 2011 | 04:29 PM
well the faster i go the better i can see.. hmm sounds good
will this being a blaster 250 with wieseco .70 bore change anything? could it handel the lights any better than a 200??
Old Oct 8, 2011 | 05:28 PM
95wolv's Avatar
Its not the engine size that determines the electric power output, the stator is rated for a maximum wattage output,the only way to increase that is with an aftermarket, like Ricky Stator, that is rewound for more wattage output. 2 strokes are notorious for their weak lighting output, most with kick start, like the Banshee and Blaster, will have a weak yellow headlight at idle, but rev it up on the trail, and it lights up real nice. With a rewind, you can get enough power that it stays bright all the time, and even do a battery charger set up, so you can run DC to the lights and maintain a battery, for even, bright lights all the time. But that is a bit more expensive, a straight rewind for more light wattage would not be much more than a standard stator, and work a lot better, especially for dual lights.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
