Kodiak 450 Wont move.
Old May 13, 2021 | 06:56 PM
Kittle93's Avatar
Default Need help
Originally Posted by 95wolv
With the belt cover off, and tranny in neutral, rev it up and see if the primary clutch spins, if it spins up, but the sheave does not close in on the belt, the primary is gummed up. If you rev it up and the primary doesnt turn much, then the wet clutch is shot and will need to be removed and the shoes replaced.
I have a Yamaha Kodiak that won’t move but a little in full throttle I do has u say an the primary closes on belt everything spins an new belt as well but when I put it in gear the primary doesn’t close wat is the problem I’m not seeing thanks for the help
Old May 14, 2021 | 02:39 AM
When you have it in gear, does the front pulley spin when you rev up. If it doesn't or just moves very slowly, the centrifugal (wet) clutch is worn out. As written above, Yamaha want extortionate amounts for a complete new assembly, but as all makers use similar components and Honda do sell shoes separately (circa $50 a set), it could be worth comparing Honda shoes for a 300, 350 or 450 and, if they are the same, fit them.
greg74
Sep 10, 2019 03:03 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
