04' 660 Grizzly maintenance.
Old Oct 6, 2012 | 02:05 PM
the Rog's Avatar
Default 04' 660 Grizzly maintenance.
Hi, Roger here, in Sac area. I have a 660 griz that has 135 hr's, and 1060 miles on it. I need's mojor service.
I checked the valves, and set them at .006 intake, .008 exhaust.
New oil and filter's.
I can't find the repair manual, or owner guide
Can someone please give me a list of important maintenance item's to do now, with that mileage and use, b4 I put it back together.
I've only ever done the valves and oil, so it need's alot i'm sure.
I have a klr650, and every 2k miles, you have to adjust the balancer shaft chain tension. Does the griz have that, or something similar. It runs fine, and I put in a new plug after 8 yr's. So any info I can get from you guy's will be much appreciated. 916-600-1601 if anyone is local. Thank's
Rog out.
Old Oct 6, 2012 | 03:25 PM
TLC's Avatar
TLC
With 135 hr and 1000 miles it should need nothing. What happen to it? My fiends 10 Year old 2003, 660 Grizzly with 3500 miles and 350 hrs only had one front wheel bearing changed and a battery since new, It even still has the original belt and spark plug. Motor and carb has never been touched. All he did was oil changes.
They have no grease fittings so all I can think of change the front and rear diff fluids and clean the air filter.
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
