yfm250 bear tracker bogs at WOT
Old Jun 11, 2021 | 03:00 AM
Bryantchris90's Avatar
Originally Posted by radio_spadio
Put the air box cover on, all problems solved.
This dummy learned something today. Small engines need recirculation air.
Thanks all those that read and Jaster for some input.
-radio
I had the same issue but it only works when I take the cover completely off 🤔
Old Jun 12, 2021 | 07:48 AM
I assume by that you mean the bike runs better without the airbox lid. If so, the original poster's ideas of cleaning the carb out, checking it has the right jets and possibly altering the main jet needle height, should fix it. Plug colour with the box lid on should tell you if it is weak or rich. Although intuition would indicate taking air box top off makes the mixture weaker, this is not always the case. (I believe the 250 Honda runs richer without lid). If it is running rich with lid on, check the choke is working properly, though this gives more trouble at low revs than wide open.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
essonlaker
Sep 10, 2015 01:12 PM
Elkaholic
Sep 6, 2015 02:44 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
