what would cause an atv to not idle?
Old Mar 21, 2013 | 10:06 AM
  #31
steven jaffe's Avatar
you have to be very careful going smaller on jets then stock. is everything on the bike stock .if you can just give me a call 1 day 21576 86418.this way I can actually talk to about the carb.
Old Mar 21, 2013 | 10:29 AM
  #32
your float might also be stuck shut so therefore it's not getting enough to you until you hit your throttle. do you know if the bowl is filling up with fuel ,you may not be running rich and your air screw should be adjusted to about 1 and a half turns out .
Old Jan 3, 2021 | 07:46 AM
  #33
Bert1231's Avatar
Default 2013 honda 400x will not idle at all
2013 honda trx 400x wont idle but it will start warm up and everything but will not idle at all I have cleaned all the jets in the carb and made sure there is no lines clogged please help
ricoscoro
Jan 28, 2017 05:19 AM
luke21er
Aug 21, 2010 06:15 PM
kenf66
Aug 16, 2009 12:11 PM
tphowell
Oct 9, 2006 12:56 PM
02sxv
Jan 12, 2005 08:37 AM
