scratched the surface where my crank seal goes
Old Jan 1, 2014 | 08:59 PM
johnrayner1990's Avatar
Default scratched the surface where my crank seal goes
so i was pulling the crank seal on my blaster and i wasn't being careful enough and scratched the surface. i was using the claw type puller and as i pried up it put one straight line in it. its very small but still enough to mess up the next seal I'm sure. can i use some sort of rubber gasket or something to make sure it seals properly?
Old Jan 2, 2014 | 08:17 AM
Raptor450's Avatar
How deep is the scratch? If there is any metal that is sticking up past the crank seal surface area then you will need to file/sand the crank down so that it's smooth and won't cut the new seal.
Old Jan 2, 2014 | 05:20 PM
It's on the casing surface not the actual crank in sorry I forgot to mention that. I had someone tell me today at my local cycle shack that I'm fine just some rubber gasket will do the trick.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
Jackg17
Sep 26, 2015 09:30 PM
