Old Yama Problems
Old Jan 4, 2014 | 12:55 PM
gmschaeffer's Avatar
Default Old Yama Problems
2000 wolvarine issues. Just got it. Not experienced . Mechanic years ago on "muscle cars". Feel like a baby. Anyway: Won't start bad weather, put new battery in. Must use charger in start position to help it. @ns: Carb adjustments are backwards. Float positioner is idle on these, what??? Back Brakes stuck on, no rear brakes, master cylinder shot????? I need to release them. Shifts hard, almost need hammer to shift. It has been really cold. Is in unheated garage. Any help uys/ggirls?
Old Jan 5, 2014 | 08:16 AM
BEC300ex's Avatar
I had one the same model and mine was really hard to shift too but i got used to it also the back brakes suck, if i was you take the back caliber off and see if you can get it freed. The carbs are easy on these things about 99 out of 100 i have done, a good cleaning and making sure the float is moving properly and the jets are clean will fix any problem you have. If you have a new battery i would trickle charge it over night or whatever the instructions say but make sure you get a good initial charge and you should have no problem.
Old Jan 5, 2014 | 11:41 AM
Default Thanks for the info
Thanks for your help
Old Jan 5, 2014 | 01:57 PM
BEC300ex's Avatar
glad to help
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
