*Rappy!* Raptor 660 Build Thread
Old Jan 16, 2016 | 12:22 PM
Fasteratv's Avatar
Your doing a great job! And the 660's were pretty cool in my book, I purchased a new one in 01, piped, jetted and it was quik. Mine was very reliable, no second gear issue. Only problem I ever had with it was the starter clutch and easy to replace on this particular bike. Anyway, I will stay tuned for the rest........
Old Jan 22, 2016 | 09:05 PM
Uberbricky's Avatar
Good work! I'm looking to pick up a raptor this summer, following!
Old Feb 8, 2016 | 01:53 PM
bmxatv10's Avatar
Looks like this ole' girl was running rich. That's ok, we'll get those carbs tuned right real soon [emoji41].
bmxatv10's Avatar
The a-arm bushings were a tad tired and under greased, so I picked up some bushing stock and made some new ones, as they are quite expensive to buy.
They turned out pretty good...
Old Feb 8, 2016 | 01:56 PM
  #15
bmxatv10's Avatar
The engine was one helluva greasy mess at first, but I finally got her all cleaned up and painted with engine enamel.
Old Feb 8, 2016 | 02:04 PM
  #16
bmxatv10's Avatar
A-arms were looking a mess, but I finally got them all cleaned up along with a lot of other parts.
Also found out that the carrier bearings were trashed along with the front wheel bearings....
New bearings in the front hubs.
Old Feb 8, 2016 | 07:19 PM
  #17
Fasteratv's Avatar
Really looking good. Here's the problem tho, once you get it all finished, you won't want to get it dirty... I did a 1994 Banshee, similar to what you are doing, kills me to get a scratch on it because it was sooo much work. I ride gravel roads only with it......I still have the Banshee....and again, looking good man..\
Do you have a media blaster...to do this work and.....if you do, which one is it? Thanks
Old Feb 9, 2016 | 01:32 PM
  #18
bmxatv10's Avatar
Yeah, but its not a problem, because as soon as its finished and I work any bugs out I will most likely put it up for sale anyway. So no worries
I do use a friend's media blaster with glass beads. I honestly couldn't tell you what kind it is. I'll have to look next time I use it.
Thanks for the compliments!
Old Feb 12, 2016 | 09:00 AM
  #19
bmxatv10's Avatar
Engine in!
Old Mar 11, 2016 | 12:05 PM
  #20
bmxatv10's Avatar
late night carb rebuilding:
Installing bearings into the carrier:
Silencer painted up:
