*Rappy!* Raptor 660 Build Thread
Old Sep 14, 2015 | 02:17 PM
bmxatv10's Avatar
Smile *Rappy!* Raptor 660 Build Thread
Hello all! I'm getting back into riding quads and tinkering with them. Thought that I would use this thread as mostly a motivator and log of efforts for myself. Hopefully you all will enjoy and feel free to let me know what you think of the build. Thanks.
Ok, so I picked up a pretty sweet deal on this 2001 Raptor 660 from my good friend and thought that I'd do a frame off rebuild on it.
Got her home and started cleaning up what the pressure washer left behind. It's a solid "ten footer" quad. It needs a LOT of small things to be 100% again. The only major thing wrong with this quad, that I know of, is some play in the steering.
Pulled the seat off and noticed it is already outfitted with a K&N air filter and a nice electrical box holding the battery in all snug, lol.
Also, the floats in the left carb seem to be a bit high as it has a slow drip of gas onto the motor, and it also dies occasionally after coming to a stop.
Got the plastics off and most of the big items still seem to be in good shape mechanically.
Pulled the somewhat dented Pro-Circuit T4, which is loud as $hit!, and noticed that some of the packing is blown out and probably has never been repacked.
Pulled the manifolds and bead blasted them. Stainless always cleans up well!
Old Sep 15, 2015 | 01:44 PM
bmxatv10's Avatar
Fender brackets bent and filthy.
All cleaned up, corners rounded, straightened. These should look a lot better.
I have noticed that the rear fenders don't have the best support from these tiny brackets. Has anyone else done anything different to help support these big fenders? Has anyone made extended brackets or extra brackets?
Old Sep 16, 2015 | 11:47 AM
bmxatv10's Avatar
Nasty...
Engine is now out and i rolled her outside to clean the frame some more.
This is the color that I will be putting on the frame very soon.
More miscellaneous bits cleaned and blasted.
Old Sep 17, 2015 | 07:57 AM
Scooter86's Avatar
Knows Old ATV Questions!
Excellent! I may lambaste the original Rappy from time to time, but properly set up they are actually a great quad. Glad to see someone bringing this old war horse back to her former glory (or most likely even better than original.)
Old Sep 18, 2015 | 11:14 AM
bmxatv10's Avatar
Absolutely, thanks. Yes, I am not the utmost raptor fan either, but they definitely deserve to be better taken care of than this. Please stay tuned for further updates!
Old Oct 20, 2015 | 03:29 PM
oblytr8's Avatar
For support on the rear fenders, I actually fabricated something out of 1/2 steel conduit. the lil tabs that bolt to the brackets broke on both sides. No flapping since I made the new brace.
The bead blasted parts look awesome! What type of glass bead are you using?
Since this is an 2001, does it have the tranny mod? Might be a good time to correct that issue while you have it apart.
Old Oct 20, 2015 | 09:38 PM
bmxatv10's Avatar
Thanks for the conduit idea. I might have to do something similar.
I'm just using glass bead media, that's all I know, lol.
I'm not sure if this quad has the "tranny mod" done to it or not. But it runs and shifts excellent and has for a long time so I have no worries. I will not be tearing into it.
Old Oct 21, 2015 | 10:32 AM
oblytr8's Avatar
The early 01 660s had a tranny issue with 2nd gear. They corrected the issue in the later 01 models. Hopefully you have one of the later models.
I use glass bead as well, but I am thinking what you are using may be a finer grit. Your bead blasted parts look a lot better than mine. lol
Old Nov 11, 2015 | 01:50 PM
bmxatv10's Avatar
Swingarm is off and I found some bushing problems!
Stripping...
Tie rod ends are bent to hell.
Moar blasting!
At some point, someone has wheelied the **** out of this quad and bent up the subframe a bit as well as ripped off the grab bar.
Cleaned, deburred, and primed.
Cleaned up and smoothed the area near the footpegs.
Finally, today I've been concentrating on some carb cleaning.
File Type: jpg
Old Jan 4, 2016 | 12:48 PM
bmxatv10's Avatar
I finished smoothing and finishing a few parts of the frame and got the primer sealed.
Basecoat:
Red Metalcast:
It really needs one final wet coat to be "complete." IMO
Pro-Circuit T4 Mods: The silencer originally had a huge dent in it, so I hacked it off behind the dent and just made a shorty silencer, a: because I thought it would look cool and different, b: because I doubt that anyone else has one, and c: because who cares! And, yes.....I do realize that it will be loud as ****!! No surprise there.
I have collected some parts recently to begin rebuilding the quad, so that should be under way very soon! Stay tuned!
