Raptor 50 to 80 conversion
Old Aug 14, 2016 | 06:21 PM
Shootenbulls's Avatar
Default Raptor 50 to 80 conversion
I have a 2007 Raptor 50 that's doesn't have any compression, and I can't find the jugs or pistons online for it. So I was wondering if the jugs, head, and pistons for the 80 will fit the crankcase. If it's been discussed before or you can steer me in the right direction for parts for it would be greatly appreciated.
Old Aug 15, 2016 | 02:35 AM
You should be able to get an oversize piston + rings from any Yam dealer, and get the cylinder bored to suit it. If you haven't already checked, you may just need rings, as they seem to wear a lot faster than bores on 4 stroke ATV engines. By the way, did you check valve clearances, that engine is notorious for loosing valve clearance and therefore, compression.
Old Aug 15, 2016 | 11:50 AM
I will take a look. I have never dived this deep into one. Rewired a couple of Chi-honda clones, but nothing to mechanical. Any pointers?
Old Aug 16, 2016 | 03:15 AM
Check the valve clearances before delving into the engine, you may not need to go any further.
Old Aug 16, 2016 | 08:35 AM
410Customs's Avatar
Off Road Builderaholic
agreed check valves
They get tight and will not start easy
Adjust valve lash and they fire right up
Old Oct 2, 2017 | 09:07 PM
Checked the valves and turns out they where damaged by something internal letting go. Took apart the engine found bent valves and damaged piston. New piston, rings, valves, was the cure.
vinnyr27
Aug 20, 2016 01:38 AM
tworthington95@gmail.com
Aug 15, 2016 12:17 PM
bkb72
Aug 12, 2016 09:29 AM
mtnxtreme
Aug 11, 2016 11:53 AM
dwash89
Aug 8, 2016 02:30 AM
