Removing Warrior Parking Brake?
Old Apr 18, 2001 | 01:41 AM
krazee's Avatar
I recently took the parking brake off of my 2000 Warrior.I am waiting for the brake block off i ordered.My question is there is a switch located by the clutch lever that when not pushed in causes the quad to cut out and not run as it thinks the parking brake is activated.Can i remove this switch somehow and any help would be greatly appreciated thanks!
Old Apr 18, 2001 | 10:22 AM
RaptorZone's Avatar
You can just unplug the switch and it will stop.
Old Apr 21, 2001 | 01:11 AM
krazee's Avatar
O.K.
I unplugged the switch and it is still cuttin out.
Do i have to remove it from the C.D.I. box?
Thanx again!
Old Apr 21, 2001 | 01:45 AM
RaptorZone's Avatar
OK, I think I got mixed up with the clutch safety switch. On the E-brake switch you need to connect the wires together. Sorry 'bout that.
Old Apr 21, 2001 | 06:49 AM
krazee's Avatar
So i just cut the switch thing off the end and crimp the two wires together?
Old Apr 21, 2001 | 12:05 PM
RaptorZone's Avatar
The best way to do it to just unplug the switch from the wiring harness and make a little jumper wire with the correct crimp on ends to connect the old wires together.
Old Apr 22, 2001 | 04:49 PM
warrior3443's Avatar
Is this on every year warrior or just the new ones? I have a 96, will it be ob mine?
Old Apr 23, 2001 | 01:21 AM
Faraday's Avatar
Hey RaptorZone, you got squashed on ********* by Screamin96 I don't think he liked your links
Old Apr 23, 2001 | 12:10 PM
RaptorZone's Avatar
LOL, I see that.
Old Apr 23, 2001 | 02:26 PM
krazee's Avatar
O.K. i got an idea of how to do this but im a jackass so could you kinda explain it a little more in detail for all us jackasses?
I would appreciate it alot.
Then i can take the damn duck tape off of my lever that im usin to keep the switch pushed in!
DONT LAUGH!
Thankx
