i have a 99 big bear 350 and it will not start
Old 10-30-2017, 09:03 AM
weeza123's Avatar
Default i have a 99 big bear 350 and it will not start
i have a 99 big bear 350 it will not turn over but the natural light comes on but when i straight wire it to the starter it will start right up does anyone have any ideas
Old 10-31-2017, 04:19 AM
Probably faulty solenoid, if it clicks but the starter doesn't spin it almost certainly is the solenoid. If it doesn't click, it still may be the solenoid, but other possibilities are start button faulty, or the wiring between ignition switch, start button and solenoid, or neutral "lock-out" circuit.
Old 10-31-2017, 09:12 AM
weeza123's Avatar
Default big wont start
ill try later do you no were the fuses could be cuz the lights don't work and they have new bulbs
Old 11-01-2017, 04:17 AM
Afraid it is years since I worked on one of those old Big Bears. Just a thought, does a wire from ignition switch go to the start button and lighting switch in the LH handlebar switch box? If so, and that wire broke, or had a bad connection where it plugs into the loom, it would put both start button and lights out of action.
Old 11-01-2017, 09:34 AM
weeza123's Avatar
Default big bear 350
ill look but the tail light works and do you no what i could do to get it to fire up quicker and would you no why it backfires thanks
Old 11-01-2017, 01:45 PM
tn rdg rnr's Avatar
Might try a new plug if that don't work check the valve adjustment.
banoose
10-31-2017 09:15 PM
CFH420Pistolas
10-11-2017 04:23 PM
mcquiver
10-09-2017 05:06 AM
Gilb2000
10-06-2017 02:19 AM
Quick Reply: i have a 99 big bear 350 and it will not start
