1996 Yamaha Timberwolf 4*4
Old Nov 13, 2017 | 12:26 PM
Redneck01's Avatar
Default 1996 Yamaha Timberwolf 4*4
I just bought a 1996 Yamaha Timberwolf 4 by 4 four wheeler. It didn’t have a manual but I’m trying to figured out why it smokes when I go through water and what kind of oil I should put in it?
Old Nov 15, 2017 | 03:41 AM
Is it not just the water turning to steam when it hits the hot exhaust and engine cases?
If you are getting blue smoke from inside the exhaust, check the engine breathers are connected to the airbox, and if the are not, change oil right away, as you probably got water in the crankcase, which lifted the oil level to where it got burnt, but was replaced with water.
Any 10/40 engine oil is OK if it is suitable for motorcycles (oil immersed clutches).
Old Nov 15, 2017 | 07:40 AM
Redneck01's Avatar
Will it mess up my four wheeler when’s it hitting the hot engine? Thank
Old Nov 16, 2017 | 04:04 AM
No, Quads are made to go through fairly deep water. Yamaha's electrics are not the best protected against water getting in, but should be OK in normal use.
Strickland84
Aug 10, 2016 03:30 PM
lakota10567
May 5, 2000 01:52 AM
cj7
Nov 18, 1999 12:10 AM
Rob
Aug 31, 1999 11:37 AM
KevWarrior
Aug 4, 1999 06:40 PM
