starter keeps turning over
Old Nov 16, 2017 | 07:09 PM
groutguy's Avatar
Default starter keeps turning over
sometimes (Not all the time) the starter keeps turning over when you turn the switch key off. You can turn on the kill switch , doesn't matter . The only way it stops is , turn the switch key off while pressing the start button and flicking your thumb off it.?I've replaced solenoid, starter switch,starter/kill switch. Please help
Old Nov 17, 2017 | 03:20 AM
Well it is the solenoid sticking as, once you turn the ignition off, no power is going to the start button. However, we have had this problem after fitting new solenoids too, and the reason seems to be a weak battery. My theory is this slows the solenoid down enough for the contacts inside to arc and stick together once engaged.
Old Nov 17, 2017 | 11:57 AM
groutguy's Avatar
Smile starter keeps turning over
hot wire from the battery goes to one side and wire from solenoid to starter on the other. two small wires come from solenoid to a plug. blue and red. after looking at the old solenoid I realized that the wire from the battery goes to the red wire side . I had it hooked up backwards. I didn't even know it would start hooked up backwards , but yeah it started hooked up both ways . I think I have it . Thanks for your help .
polarisrider1203
49
Mar 26, 2017 05:30 PM
Dageaux504
Jan 22, 2017 05:38 PM
Fanatic ATV Guy
Nov 21, 2016 11:55 AM
famosrichit
Nov 4, 2001 04:47 AM
