99 Wolverine 350 electrical problem
Old Mar 18, 2018 | 05:31 PM
maconauton's Avatar
Default 99 Wolverine 350 electrical problem
I have 99 Wolverine and it want start. I have replaced starter, starter relay and battery. The neutral light comes on when key turns on. Check everything with a test light but just can not get power past the relay to the starter. What would keep it from starting.
Old Mar 18, 2018 | 05:54 PM
Don't know if your solenoid is in a rubber boot or not like some Yamahas,or is grounded to the frame,but make sure all grounds are good.If the solenoid grounds to the frame,scrape a little paint to bare metal. May be something simple causing the problem.
Old Mar 18, 2018 | 08:33 PM
maconauton's Avatar
It has a rubber piece around the relay then two wires that plugs into the other electrical components. The power comes from battery but I can not get it to the starter side of the relay to go to the starter.
Old Mar 18, 2018 | 08:44 PM
Solenoid trigger wire may not be getting power from the start button on the left control switch.You might see if electrical contact spray in the crevices of the switch may help on this.
Cassandra Mitchell
Apr 23, 2018 05:28 PM
92bear350
Jan 21, 2017 02:14 PM
ChrisPollock
Oct 5, 2000 06:38 PM
BillMullett
May 22, 2000 08:28 PM
