86 moto 4 80 wont start cold by electric.
Old 03-21-2018, 01:18 PM
youd's Avatar
Default 86 moto 4 80 wont start cold by electric.
my 86 moto4 80 will not electric start unless you push start and get the motor warm then it run and starts fine has new battery ,jets and pitcock
Old 03-21-2018, 05:00 PM
Jered651's Avatar
That is a sign of a weak stator. Could be valve lash too but that sounds backwards for that problem. grab your multimeter and ohm out the stator.
Old 03-22-2018, 04:22 AM
Not sure if the 86 models were two stroke or four, but Yamaha's four stroke 80 is notorious for the valve clearances closing up, giving exactly those symptoms.
Old 03-22-2018, 10:58 AM
LT80's Avatar
LT80 Expert
ooops. Might be wrong so I deleted..
but ours was a 4 stroke. Gutless wonder but ran good.
Old 03-23-2018, 04:21 AM
Had a Breeze in this week with the same symptoms and no compression, sure enough, checked valve clearances yesterday and inlet valve was open all the time, gave it 0.003" clearance and it started on the button.
atvpredrider500
12-23-2012 05:27 PM
jbutle01
01-27-2010 06:52 PM
03250bayou
04-10-2007 01:37 AM
quadracer18
10-05-2004 02:06 AM
shastadog
01-26-2004 09:59 PM
Quick Reply: 86 moto 4 80 wont start cold by electric.
