Yamaha blaster bogging problem
Old Oct 24, 2018 | 09:56 PM
Boostwhipped's Avatar
Default Yamaha blaster bogging problem
Hey guys so I have a 2000 yamaha blaster I rebuilt the motor weisco crank and weisco piston bored .40 over. It ran great for about 10 hours then all of a sudden one day it started up and ran like crap. It just boggs down and has no power and even sounds bad and dies. I took it to a mechanic he said he fixed it but he didnt and he will no longer help me with it so I got screwed. I have tried cleaning the carb multiple times it has 360 main jet and 32.5 jet. Also the reeds look good but the carb and reeds did have excess oil built up on them and I'm running 32:1. Any ideas why it keeps bogging and dying on me?
Old Oct 25, 2018 | 03:10 AM
If you are sure it isn't the carb, have you checked the exhaust? Usually exhausts plug slowly, so it sort of creeps up that they won't rev, but a loose baffle etc, can cause a sudden loss of power. bike will idle, but not rev. I go for removing it and starting up without the exhaust, only do this where nobody can hear you, and wear ear plugs. If most of the power is suddenly back, you have a plugged exhaust.
Old Oct 30, 2018 | 09:51 AM
Lt Granddad's Avatar
Is the 360 correct I’m reading for the main jet you’re running? Sounds way to high. What other mods on the quad, open air box?
Old Oct 30, 2018 | 10:42 AM
that's what I thought to so I ordered smaller jets and they should be here today. But it is bored .40 over with weisco piston and weisco crank, air filter and exhaust
Old Oct 30, 2018 | 11:26 AM
I’m thinking around 250,260 to 270. 230 is factory.
Old Oct 30, 2018 | 11:28 AM
I have on order coming today 330,340,350. So you think I should go way smaller then?
Old Nov 5, 2018 | 10:56 AM
Timbo2500's Avatar
Default Did the new Jet help?
If the newer Jet didn't solve the problem and you have ruled out a few problem don't overlook an electrical probl like a bad CDI. I had a similar thing happen to my 2008 Big Bear and everyone told me there was no way it could be a bad CDI because they usually go bad and you lose spark completely. Mine would allow it to start and mimic such problems as a gummed up carb or worn out cam. Basically no power, it would bog down and didn't want to move. I swallowed my pride and my cash and took it to a "pro". They changed the Stator, rebuilt the carbs and $450 later it still ran like crap. Finally I bought a Chinese CDI off eBay, plugged it in and it ran like a dream!
Old Nov 6, 2018 | 07:58 PM
MrSummit's Avatar
If it ran great for 10 hours I doubt it is the jetting. Did you check the plug color during the 10 hours?
Did you follow any break-in procedure?
Correct oil level?
The main jet for a 2000 blaster is supposed to be an 80 according to a few parts fiches I looked at. Doesnt make sense. The blaster forum concurs with above comment that stock is 230
Try www.blasterforum.com
Old Nov 29, 2018 | 08:39 AM
Hey guys sorry it's been awhile but I finally got new smaller jets tried those and installed a new coil and cdi and still will not start. Any other ideas I could try?
Old Nov 30, 2018 | 03:25 AM
Have you checked for a spark? Did you try it without the silencer?
