Raptor 700 backfire
Old May 28, 2019 | 01:16 PM
Lukeamm's Avatar
Default Raptor 700 backfire
Hello I have a 2008 raptor 700r... Stock. the baffel came loose and then just shot out the back, I've heard of guys taking them out so i thought no big deal. But since that happened, it's been not wanting to idle and backfiring especially on start up. Does it need that back pressure? Or do I need to mess worth the air fuel ratio since the exhaust is now modified. Is it maybe a fowled plug or valves out of adjustment? Thanks for the help
Old May 29, 2019 | 05:00 AM
Could be any of your suggestions. So, fit a new plug, adjust the valves. If that doesn't work you could try cleaning and adjusting the carb. One reason for a bike blowing it's baffles out is incorrect air/fuel ratio anyway so you could have been running lean before it blew them out, due to dirt in a jet.
Old May 29, 2019 | 08:35 AM
Lukeamm's Avatar
This bike is EFI, so could it be electronics that are off?
Old May 29, 2019 | 08:38 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Isn't The Raptor 700 fuel injected? Check the valves. Also a new plug can't hurt.
Is the backfire coming from the intake or the exhaust?
Old May 29, 2019 | 08:39 AM
Lukeamm's Avatar
Exhaust
Old May 30, 2019 | 02:30 AM
"This bike is EFI,"
My apologies, on most Quad EFI systems you can't "mess worth the air fuel ratio" so I assumed carburettor. More likely to be dirt in the injector or a blocked fuel filter than the electronics giving trouble. Though a sensor telling the ECU lies can cause all sorts of problems, and it is extremely difficult to diagnose unless it throws a fault code up, which can be read by diagnostic equipment.
gvance
May 18, 2008 10:34 AM
KEITH1966
Technical and How-To Articles
Apr 4, 2008 05:51 PM
ssms82965
Dec 17, 2007 01:28 PM
spjohn
Nov 9, 2004 07:05 PM
bartolo
Jan 4, 2001 09:21 AM
