2001 warrior 350 starting problem
I have an 01 warrior that wont start up on its own. It has to be jumped from a vehicle, starts right up when jumped. It stays running and is operational. But as soon as its stalled or killed it will not start at all. No pwer to anything, no lights no neutral light no noise. Not even clicking from the starter. Battery has been replaced and has about an 85% charge
Any ideas what the problem may be.
Thanks buddy, ill start there. And just to be sure, you said "stator" not "starter" right? Could it be the magneto?
It isn't the stator if you get the electrics working when you tow start it as the stator is then providing the power. Don't know the Warrior but most Yams have the main fuse on the solenoid, if that blows you get the symptoms you describe. However this solenoid/fuse assembly also requires the big terminals on it to be connected the right way round, M binding post to motor, B post to battery. Very common for people to connect these the wrong way round, which again gives those symptoms.
ChrisYamaha
Jun 23, 2017 01:07 PM
