1995 Wolverine 350 intermittent no spark
I have recently acquired a 1995 wolverine 350. After a carb clean it ran great. I got it with a junk battery. I replaced the battery and now I have no spark. I have an issue with the connector from the ignition switch. Sometime it won't crank. I thought I had an issue there. I was hoping someone had access to a repair manual with a schematic of the stator. It is electric start only. I have checked all the connections. Everything seems good. Except at the ignition switch I have a black with white wire that spikes some high voltage. I have a vast knowledge in automotive repair. At 1 point I had coil pulse on the orange wire and then that dropped out. Hence why I am thinking stator. I would love a schematic or specs on the stator so I can ohm test it. Thank you for your time.
