Yamaha blaster
Old Apr 24, 2020 | 11:49 PM
NashSmith's Avatar
Default Yamaha blaster
Need Iittle help guys. I just put a new top end in a blaster I had stored since 2005ish. but I parked it after riding it a little after I got top end together and nextday the fuel tank was empty float was stuck and drained the fuel into cylinder. problem is that now I have gas In my gearbox. Im thinking being 2stroke thats not right. Anyone seen this before. do I have a crankSeal out? never been in bottom end of blaster not surewhat it could be
Old Apr 25, 2020 | 10:15 PM
Lt Granddad's Avatar
Probably just crank seal clutch side. Was the idle erratic when it was running.
Old Apr 26, 2020 | 01:56 AM
NashSmith's Avatar
Running fine till parked it thats when it flooded I believe. I juat put new kit in carb so no more flooding ran it for a min doesnt seam to be putting anymore gas into gear box. I'm confused
Old Apr 26, 2020 | 03:53 AM
Fuel has found it's way past the crank seal into the clutch/gearbox side. A little fuel/air mixture is now going to get past when the bike is running, but nothing like as much as when crankcase was full of fuel. It will affect performance, as some air /fuel mix will be escaping, so it will need a new seal, but you can put the job off for a while. See my answer to "serious Yamaha Moto4 issues" about why your crankcase got full of fuel in the first place, too.
Old Apr 26, 2020 | 08:05 PM
NashSmith's Avatar
Thx for the help guys
bigbaker
Jun 10, 2008 08:25 PM
hoover650
Dec 5, 2002 08:07 PM
ZacIseMan24
Jun 30, 2001 02:13 AM
