1997 Yamaha Big Bear 350 4x4 Winch Mount
Might be hard to find one to purchase new considering the age. I looked for one for my 98 Timberwolf a little while back and came up empty handed. Figured the only way I'm going to get a winch on it is by building my own mounting plate.
Wish it was as easy as my Bruin, which had mounting tabs already in place on the frame where I just bolted on a Harbor Freight mounting plate that cost $5 and the winch bolted right onto it. I will probably use another $5 plate to build off of and fabricate my own winch plate for my Timberwolf. I've seen people using the U shaped exhaust clamps to mount the plates to the frame bars of a Timberwolf. Not sure how the Big Bear frame is set up in the front, but you might be able to do something similar if you cannot track down a ready made winch plate.
https://atvconnection.com/forums/yam...-s-please.html
DanielleDorman
08-04-2017 01:01 PM
