What kind of Yamaha is this?
Old Sep 16, 2020 | 10:08 PM
thall320578's Avatar
Default What kind of Yamaha is this?
Looking for a parts quad or something to just rebuild.
I stumbled on this listing, and I've messaged the seller about possibly getting me the VIN so that I could decode it, but figured I'd test out the knowledge here on the forum
Seller claims it's an 06 Kodiak 450 4x4. But looking at the pictures, it has a solid rear axle, whereas I though the Kodiak has always had independent rear... To be honest, all of the plastics look identical to my 04 Bruin 450 accept for the front pieces, and the front bar. The rear end even looks the same... So I just don't know lol.
If nothing adds up from you guys's ID, and the VIN reports back as a Bruin, maybe at some point some parts have been swapped around on the front from a Kodiak? Either way if it does end up being a Bruin 350 4x4, then this wreck would be PERFECT for my needs to convert my 2wd into 4x4
Thoughts?
Old Sep 17, 2020 | 02:35 AM
Just checked the on-line parts books and the 06 Kodiak is IRS but the 04 is swinging arm, we maintained a few swinging arm Kodiaks. I remember needing a seat for one, tried swapping it with the seat from a scrap Bruin we had, seat didn't fit, so although the plastics look identical, they are not. If the Kodiak is cheap and needs little work, buy it, mend it and use it, forget tearing both machines apart to try to make one front end fit t'other.
Old Sep 17, 2020 | 02:08 PM
Comparing 04 Bruin to 04 Kodiak, is the Kodiak physically larger than the Bruin? Would you now if dimensionally the frame and suspension parts are similar?
I only wonder because looking at the photos, the frame looks to be pretty tweaked, looks like it hit something in the front AND rolled over... Not so sure that it would be rebuildable unless I had a complete replacement frame, possibly some suspension parts in the front... BUT, if the Bruin and Kodiak shared similar dimensions, mounting points for suspension components and even the engine, then I could just use this rolled over one as a parts quad, get what I needed to and transplant it onto my Bruin, and part out whatever's left.
I know the Bruin and Grizzly are brothers, just wasn't sure how the Kodiak fits into that trio...
Old Sep 17, 2020 | 05:55 PM
Guess it doesn't make much of a difference any more. Seller never got back with me and now the listing shows sold...
Old Sep 18, 2020 | 02:46 AM
He who hesitates--- I have fixed a few bikes that have rolled, racks, bull bars and handlebars bend first, but frames, A arms etc, are often OK, much worse is when a bike hits something solid with a front wheel.This tends to bend the A arm and twists the frame. May not even be noticeable but is extremely difficult to fix.
Old Oct 14, 2020 | 12:04 AM
Andy Bassham's Avatar
You did ok to pass that up. That front end hit something and buckled up. There was some stuff that would be expensive to fix going on there
Brett Boisvert
Jun 28, 2019 10:27 AM
army_eod
Dec 11, 2017 02:21 PM
CALL911
Oct 23, 2016 09:25 AM
WillPalmer
Mar 22, 2011 08:02 PM
