Latest upgrade to my Moto 4
Old Sep 19, 2020 | 08:08 PM
Yamyrider's Avatar
Default Latest upgrade to my Moto 4
Just finished upgrading my rear brakes to hydraulic and installed a brake light. Was tired of having to adjust the brake cable every few hrs. Over the past couple of years I’ve changed the factory rims to 12” Grizzly rims all around with 3” spacers on the rear with 26” Dirt devils on rear and 23” Ambush on front. Installed a 20” light bar(high beams) and given the plastics a fresh coat of khaki paint. I’ve owned her since new and figured it was time to show her some love. Have to admit I haven’t been gentle with it and its one tough machine.
Old Sep 20, 2020 | 09:54 PM
thall320578's Avatar
Looks good!
Would love to do some sort of retrofit like this on my Timberwolf, I despise those darn cable drum brakes lol
Old Sep 21, 2020 | 07:25 AM
Yamyrider's Avatar
Default Thanks
Yeah I know what you mean about the front brake drums. I find the seals never worked well and found the brake liners would compressor me off and jam up the brakes. Really only use them for parking. I am looking into upgrading them as well.
Old Sep 22, 2020 | 02:51 AM
Fact is, all brake systems have their good and bad points. Yamaha were "early adopters" of rear disc brakes, using them on many 90s Big Bears, but must have had problems as they went back to drums circa 2000. Then back to discs, then "wet brakes" inside the diff, not sure what they use now, but I think the most recent Yam I worked on had a transmission disc brake on the outside of the diff. Discs are fine if you use them every day, but lay the bike up for a while and the slider pins for the sliding calipers will seize, sometimes pistons will too. Wet brakes seem the most reliable, at the expense of requiring a diff rebuild if you ever need new linings.
Old Sep 22, 2020 | 05:54 AM
Yamyrider's Avatar
Default Good to know
I haven’t had a chance to use the retrofit yet. I’m using an aftermarket caliper for a Yamaha Rhino 660
and generic master cylinder and the oem rotor set screwed in place. I’ll pay attention to the sliders and piston on this too just in case. At least I won’t have to adjust the damn thing every few hours.
Old Oct 9, 2020 | 09:37 AM
reesewon's Avatar
Looks amazing! Great job! Are you able to let me know what part numbers you used to get a hydraulic caliper/kit? Is it universal, or specific aftermarket for the Moto4?
Old Oct 9, 2020 | 10:11 AM
Yamyrider's Avatar
Default Nothing Moto4 specific
I used an aftermarket caliper for an 06’ Yamaha Rhino 660. The brake line, brake switch and master cylinder are generic. All the parts I found on Amazon. I had to fabricate a mount from 1/4” steel plate. The mount for the master cylinder was made of 1/4” aluminum plate all of that was custom made to fit.
WhiteBros440EX
Mar 8, 2005 10:00 PM
Jeffksf
Jan 21, 2000 08:57 PM
hot_shoe_cv
Oct 12, 1999 08:32 PM
