Speed Sensor Test
Old Jan 17, 2021 | 07:49 PM
GWgame's Avatar
Banned
Default Speed Sensor Test
I have a 2005 Grizzly 660. I just replaced my display. Anytime I am moving it reads 0 mph. I have confirmed that the three wires, one ground, one to the CDI, and one to the meter, are good. Is there a way to test the speed sensor?
Old Jan 18, 2021 | 04:03 AM
Only got the Grizzly 550 book but it says, ignition on, use 20v voltmeter, set meter to DC, pos to white wire side, neg to dark blue side and spin the rear wheels slowly while jacked up, voltage should cycle from 0.6v to 4.8v and repeat.
Old Jan 18, 2021 | 10:45 AM
GWgame's Avatar
Banned
That is useful, thank you. The 660 manual I have completely forgot to mention it. I will give that a try.
Old Jan 18, 2021 | 05:31 PM
GWgame's Avatar
Banned
Well, that's why the speedometer is at 0. I got 0v all the way around.
Old Jan 19, 2021 | 03:35 AM
Because ignition has to be on, I assume you must have to do this with the sensor plugged in, they do show a strange drawing in the book which I assume is something to enable you to test wires while connected.
z1486
Mar 29, 2015 10:01 AM
nottelybill
Aug 22, 2012 08:59 AM
stendori
Oct 2, 2011 05:38 AM
cobby
Nov 23, 2006 07:31 PM
BansheeBrad
Jun 2, 2001 03:12 PM
