Timberwolf Pull Rope Starter
Old May 9, 2021 | 12:07 PM
djordan3's Avatar
Default Timberwolf Pull Rope Starter
Can you add a pull rope starter to a 1994 Timberwolf 250 4x4? It only has an electric starter now. If so does anyone have a part #?
Thank Alan
Old May 10, 2021 | 02:29 AM
Just checked parts books and the 4WD version J had a pull start as standard, but the case is no longer available, so a pull start from a scraper is your only option. Don't forget you will need the bit that goes on the crankshaft too. Never had much luck with Yam pull starts, they always seem to be seized up when you actually need them.
Robbie79
Sep 1, 2009 07:20 PM
peetey
Feb 17, 2006 10:10 AM
RhinoRaptor
Nov 20, 2005 08:07 PM
skidkid
Dec 23, 2000 05:03 PM
