1984 Moto4 80cc Sputtering under load
Old Sep 1, 2021 | 12:49 PM
JustRangerThings's Avatar
Default 1984 Moto4 80cc Sputtering under load
As the title states, my 84' moto4 80cc sputters when under load, but more specifically, and strangely, runs great on full throttle, or when you are just resting your thumb on the throttle, with just enough pressure to get off idle. Another thing is whenever I choke it, the roles seem to flip. Runs like **** under hardly any throttle or full throttle, but runs great under partial throttle. I'm assuming its something carb related, but I've never seen this before, and I'm pretty experienced when it comes to diagnosing problems and fixing them. No amount of tuning has helped. I'm just stumped. For some extra info, its a brand new carb, and has fresh gas. I believe it still has the original coil and CDI, so im not sure if those are what may be causing the problem. Thanks in advance for any help or tips! I'll try to post a video of it for a better representation when I get home.
Old Sep 2, 2021 | 02:16 AM
My guess would be your brand new carb has the wrong jets. Clean the old carb out and put it back. If it is too far gone to re-fit, swap the old jets and needle into the new carb.
Old Sep 2, 2021 | 05:34 AM
I would clean the old carb out but it’s way to far gone. Do you think I should drill out the jets?
Old Sep 3, 2021 | 02:48 AM
No, once you do that you can't go back. Clean the old jets out and fit them into the new carb, if it ran right with those jets before, it should run right with them now. Try a new plug just in case it is electrical.
Old Sep 3, 2021 | 06:29 AM
Okay, thank you.
trxrider83
Mar 26, 2020 12:24 PM
MRDS650
May 5, 2004 09:31 AM
ktk
Apr 3, 2004 04:24 PM
