Red and blue coolant light
I rolled our 2021 or 22 wolverine x4 and it landed upside down with oil spilled. The following week's coolant light will come on red than blue and the fan will turn on constantly even when we just turn it on. The engine also smoked when we got stuck. I think it smoked other times driving it, but I can't say for certain. The oil and coolant is filled where they need to be. We just bought it and we are at 14 hours and at 1i hours we take it In for a tune up. We would of took it in already we don't have a hitch or trailer. My wife and I just bought 6 acres and a house on it and she went had a new atv delivered as we didn't have a hitch or trailer. I'm looking for advice if you think a wire is loose. I thought of that but the smoke coming out throws me off.
Regarding the smoking, check the air filter. As the engine breather(s) go into the airbox, if a bike rolls, oil flows into the airbox and the filter so, once running again, the spilled oil is sucked in via the filter and burnt, causing smoking. I would guess that the lights and fan coming on are a wire loose or shorted onto the frame. I assume it is fuel injected? If so, the ECU may be assuming the engine is a lot hotter than it is, so air fuel ratio may be wrong. However I would guess it will be safe to use it until you can get it to your dealer. I work for an ATV repair company and, although we encourage people to bring their bikes in, if they can't, we will go and pick bikes up.
