95 Yamaha Kodiak 400 4x4
Old Mar 23, 2023 | 06:45 AM
StormyLive's Avatar
Question 95 Yamaha Kodiak 400 4x4
was riding it down the street and hear a squeak and a pop come from the front end area then it bows up and stops in the middle of the road and wont move forward anymore the rear end tries to push the front when throttle is given but front end wont pull just makes a popping noise. if i jack the front end up and spin the front tires the front axles turns fine no issues the front drive shaft does not spin when i do this though. as far as moving in reverse it backs up just fine no pops or squeaks it moves like it should until you shift back into high range and 1st gear then it does like i mentioned before. what could be wrong with it?
Old Mar 23, 2023 | 08:29 AM
tiha's Avatar
Sounds like the front differential is broken.
Maybe drain the oil and look for chunks?
Braunviehjohn
Mar 2, 2020 09:05 AM
kodiak4004x4,27s
Apr 30, 2015 09:14 AM
joecat07
Jul 5, 2007 12:59 AM
FARMER00
Jul 4, 2006 03:54 PM
kawasaskirules
Mar 14, 2004 08:15 PM
