Wot on startup 1990 yamaha big bear 350
Old Nov 9, 2023 | 12:55 PM
Trevor2000's Avatar
Default Wot on startup 1990 yamaha big bear 350
Was running fine when i purchased it. suddenly had trouble starting and when it did it had a lean runaway or wot. replace carb. and still has same problem. checked intake gasket and it’s good. air fuel screw does nothing. what’s the problem? any ideas?
also carb does not pull fuel from tank.
going to disconnect throttle cable and see if it helps
Old Nov 10, 2023 | 07:58 AM
Craig H's Avatar
Have you checked the inlet manifold for splits or and cracks? Sounds like an air leak between carb and engine to me.
I had exactly the same problem but on a mower last year, turned out to be an leaky inlet gasket (looked perfect but wouldn't seal so fitted a new one and all was good).
Old Nov 10, 2023 | 06:47 PM
Trevor2000's Avatar
might just throw a new intake manifold at it. gonna give it another shot, check the float level, disconnect the throttle see if she runs
Old Dec 6, 2023 | 03:32 AM
ElliotHuel's Avatar
Have you tried?
Old Jan 10, 2024 | 06:53 AM
JoeCarroll's Avatar
Seems no.
Old Jan 12, 2024 | 12:43 PM
Trevor2000's Avatar
Originally Posted by JoeCarroll
Seems no
Originally Posted by ElliotHuel
Have you tried?
Now it’s not even starting, i posted a new thread and a guy said it could be timing. i put new the carb to engine manifold with some gasket sealer. Been busy. Gonna check if timing jumped today. Also the fuel thing was cuz i barely had anything in it. I changed the spark plug so i’m gonna see if it’s that too
Old Mar 7, 2024 | 01:36 AM
KellenMontgomery's Avatar
Have you found any solution?
Spoiler
Old Mar 11, 2024 | 06:16 PM
Trevor2000's Avatar
Nope, timing looks good. just checked spark and compression they look good as well. maybe i got a faulty carb? any ideas?
alex288288
Sep 13, 2014 03:36 AM
mo11217
Sep 21, 2008 04:27 PM
