2001 yamaha wolverine YFM350 4x4 clutch issues
Old Feb 24, 2024 | 09:27 PM
Jsm wolverine 350 4x4's Avatar
Default 2001 yamaha wolverine YFM350 4x4 clutch issues
Reverse works great but when I shift the foot pedal up to forward gears it won't go all the way and engage. This happened when I was riding and the shifter rod connecting pedal to shift arm broke. I replaced this and it now won't shift into forward gears. Is there a breakdown of the clutch case and internals? Thanks in advance!
Old Feb 25, 2024 | 02:35 AM
https://www.partzilla.com/catalog/ya...shift-cam-fork
That is the parts drawing but, seeing as you have worked on them, I would guess either item 34 on the wrong spline or rod 37 not adjusted correctly.
Old Feb 25, 2024 | 01:35 PM
Thank you. I have ordered new clutch parts since I have already opened the case and figured I'd replace springs and clutch basket assembly. I also got a new shifter and adjustment rod as well.
Old Feb 26, 2024 | 03:09 AM
Only ever fixed one Yam selector problem and it was the starwheel 3 come loose. It was doweled onto the shift drum and the dowel holes had stretched, asked the local Yam dealer, and he told me to take up the slop with "plastic metal" I was a bit dubious if it would work, but the owner never complained of problems again.
Old Feb 26, 2024 | 05:21 AM
Well I've ordered a new shaft and starwheel and pretty much the whole get up. Figured if I'm going to do it I'll do it all. I plan on keeping it for as long as possible so I don't mind dumping money into it. Thanks! The star wheel is loose in and out but not sloppy in any other direction.
Old Mar 5, 2024 | 05:28 AM
AmayaRohan's Avatar
Is the clutch issue fully solved now?
Old Mar 5, 2024 | 06:18 AM
I have yet to install all the parts but will let you know. I'm debating if I should pull the motor and inspect the forks. But I don't know if I want to spend the time doing that.
Robert.Connell
Nov 19, 2018 06:35 AM
vtown98
Apr 28, 2010 10:00 AM
bigwave
Jan 2, 2008 08:46 AM
dylan
Sep 26, 2006 10:19 PM
ElectricShift
Oct 6, 2003 06:56 PM
