2006 Yamaha Blaster 5 wire stator question
Old Yesterday, 11:16 PM
eddy76's Avatar
Default 2006 Yamaha Blaster 5 wire stator question
Hi everyone I own a 2006 Yamaha blaster and it was running fine. I went on vacation for 3 weeks came back and nada no spark not firing up completely dead...
I tested all switches for continuity and all work great
I tested the spark plug with a multimeter and it reads good values it's brand new
I removed the flywheel and I noticed some odd things, to start with ALL magnet screws were loose and the magnets are out of place , still holding (barely) in place but some are broken and out fo wack... the screws were rattling around the flywheel
I will be replacing the flywheel .
My issue is different when i do a test to the stator using a multimeter I get the correct values :
Rd/White on Black 20 Ohms for the pickup switch
Red/Black on Black = no reading BUT Red Black on Green/white I get 252 Ohms
My stator has 5 wires
So my question to you is :
Can the lack of spark come from the wacked off magnets ?
Is it normal that I get no reading from the Black/red on Black and only from the Black/red on Green/white ?
Any info is more than welcome before I investigate further
Tx a lot
Old Today, 03:07 AM
Probably best to get the workshop manual, it will give tests for the stator wires and correct ohm values. Rare that the stator survives if magnets have come off, as they hit the stator and bend it as a rule. I guess loose magnets could cause the no spark issue. Eigers were notorious for it and would often run, but badly, until a magnet hit the stator hard enough to destroy everything.
Eduardo58
06-18-2024 03:25 AM
sinagoga
11-24-2019 04:14 AM
apopka_ed
02-05-2009 07:46 PM
bosstom
03-09-2008 06:08 PM
Quick Reply: 2006 Yamaha Blaster 5 wire stator question
