question on carb
Old May 14, 2001 | 05:03 PM
blastaman94's Avatar
i have a blaster and my bowl is usually filled with a lot of gas and it leaks out the over flow alot. Do i need to adjust the floats or the needle? thanx if u can help
Old May 14, 2001 | 05:27 PM
TurfBlaster's Avatar
When that happens, I think it means your float is stuck. If you have had your carb upside down for a period of time while you work on it or something, and it has the chance to dry out a little, the plunger will stick and allow fuel to over flow. If it doesn't do it very often like 2-3 times a year or something just take a screw-driver handle and tap the bowl lightly, it should stop. If it does it often, take the carb apart, clean it very good and maybe even get a new float assembly. That's all I can think of! Good Luck!
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
