bad luck, i have to now take the bottom end apart on the banshee
i finally got the banshee running with new pipes and put the swing arm back on.
find out the bottom end seal is leaking and the topend is sucking tranny oil out and blowing it out 1 pipe. runs fine, but i have to fix it before it seizes up or something.
also a bearing squeeled and a water pump gasket it shot.
have any advice at to what else to check while i have it apart? anything i should mod while its apart? should i lighten the flywheel? weld the crank?
badgerboy1
09-26-2017 06:11 PM
