please help me make my warrior hang with a 400ex
Old Jun 4, 2001 | 10:52 AM
JoshCVBz's Avatar
Geez, you guys lost me a long time ago. One question, how do you figure out what the "stroke" is? Looks like you need it to calculate the new cc's. Maybe I'll understand some day. Later.
-Josh
Old Jun 4, 2001 | 10:57 AM
BansheeBrad's Avatar
Stroke doesn't change with a bigger piston, so just use the stock stroke figure. All the stock bore and stroke figures are publsihed at www.yamahausa.com
Brad
Old Jun 6, 2001 | 10:59 AM
GraydonBlaster's Avatar
.020" is 2/100ths of an inch it probly is .5mm I'm not sure. Any way its not much just enough to put a fresh surface in the cylinder bore. It is hard and expensive to make a warrior as fast as a 400ex it would require a big bore or stroker kit to run side by side with a 400ex. I would buy a new pipe, cam, and have the head ported. They are reasonably cheap compaired to an engine kit. You could gear your warrior to go as fast as a 400ex but the 400 would be way ahead of you by the time you got wound out.
Reactant
Mar 30, 2022 02:08 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
metal249
Jul 28, 2015 09:35 AM
Reactant
Jul 16, 2015 10:29 PM
