Blaster Rebuild
Old Jun 22, 2001 | 05:11 PM
TrailblazerKid250's Avatar
Does the Blaster's engine need to be rebuilt every year? Does the clutch burn out easily? That's what my friend says. He says I shouldn't buy it. But get this he says, "can i ride it when you get it." I think he doesn't want me to get it because I'll beat him in a drag.
Old Jun 22, 2001 | 05:36 PM
MXFullBoreBlister's Avatar
First off, NO. The Blaster does not need a rebuild every year. (although it may be a good idea) It is only like 100 bucks to freshen up the top end, with OUT punching it out anything past stock. Second, no again. The clutch does NOT burn out easy unless you dump it, ride it(the clutch, etc. The blaster is a good machine if you take care of it. The only problems I have had is the one I have right now, the inner most baffle in my pipe has broke loose and is robbing me of HP by sitting around in my expansion chamber. But, I will get a new aftermarke t exhaust which will cure that problem. Some things you need to know...1. the brakes suck, they need constant mantinence. but if you do not ride through alot of sandy mud then there OK.
2. The tires suck. The first mod that u should look into for a blaster is tires on Rims all the way around.
3.Exhaust-the stock pipe suck goat ****. Period, look at exhausts from trinity, CT, and PowerPros.
4.Fun-if you DONT want to have fun, or if you are afraid of having a good time, then the Blaster is not for you.
Good luck, and safe riding.
Old Jun 26, 2001 | 07:34 PM
YZBlaster250's Avatar
Word Blister.
Old Jun 26, 2001 | 07:51 PM
scramdaddy400's Avatar
I owned a '96 blaster and I rode it hard, then after I sold it the top end blew and the clutch was on its way too. Six years is'nt too bad for a top end and clutch.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Beeline08
Nov 11, 2016 04:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
