changing warrior gearing need suggestions
Old Jun 22, 2001 | 08:35 PM
tuckerabbott's Avatar
I would like to change the gearing on my warrior. The bike is fine but would like just a little more torque. What size front gear should i go with and what size on the rear? Also, would a different carb other then my stock carb help with the torque? Thanks all!!
Old Jun 22, 2001 | 11:12 PM
ridnwarrior's Avatar
Use 1 tooth less on the front sprocket. Leave the rear sprocket the same. This will give you an idea if doing this was the right move. Also changing the front sprocket is alot cheaper than changing the rear.
Try it and see if that is what you're after.
As far as changing the carb, leave it be. For that cost change the silencer and you will have more torque.
You could also put a jet kit in it. I heard it gives a 5% gain in horsepower.
njrider64
Jul 4, 2017 01:40 AM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
yambam13
Jul 4, 2015 01:49 PM
Nelson
Jun 20, 2015 01:59 PM
