Grabbing neurtal instead of 2nd!!!
Old Jun 27, 2001 | 12:35 PM
01Raptor660R's Avatar
I posted something like this under a different thread about the Raptor. Only the part about searching for neutral after stopped. I changed the oil and checked the free play of the clutch before the last time riding and still had a hard time finding neutral. This doesn't happen all the time. Sometimes you can find neutral real easy. We have been playing around with it and noticed it might be a half click up or a slight click up or sometimes a full click to second and a slight click down. I'm not really sure. Haven't had many problems with missing second gear. If it happens to me it is because I had the wrong angle on it under the shift lever when trying to pull it up or I didn't push it up far enough to click it in.
Old Jun 27, 2001 | 01:53 PM
mtecate4g's Avatar
On warriors as well as raptors they have a linkage run shifter. after they break in they have to be adjusted or miss shifts will happen. Also check for proper clutch free play(1/8in). I can bet after you adjust your shifter down a hair it will shift great.
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Sep 20, 2015 10:21 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
PrairieDog126
Sep 12, 2015 05:23 PM
