black banshee plastic
Old Jun 25, 2001 | 11:22 PM
discharge's Avatar
anyone know where i could get some.....mine are crap.....i could probably put 2002 fronts on it(if you can buy those) and try and find some rears....thanks
Old Jun 26, 2001 | 01:22 AM
chicneater's Avatar
Look thru Dirt Wheels.....you can find UFO plastic in white, YZ blue or black for around $270 for both front and rear plastics.
Old Jun 27, 2001 | 10:37 AM
discharge's Avatar
kick *** thanks
Old Jun 27, 2001 | 11:18 AM
JoshCVBz's Avatar
Does the Black plastic leave the same "stress marks" as the blue does when it gets bent? Thanks.
-Josh
Old Jun 27, 2001 | 03:19 PM
chicneater's Avatar
you know, I'm not sure if it would or not. I would assume you would see the white stress marks, just like you would with red, blue, yellow, etc; simply because all it is a color change, still the same plastic and process when manufactured.... white being the only one that doesn't.
Old Jun 27, 2001 | 03:23 PM
JoshCVBz's Avatar
When I rolled my Polaris it bent one of the fenders quite a lot and I cannot see any white stress marks anywhere (it's yellow). My buddies blue Banshee, and another friends Blue Warrior show the white marks like after just a small bend. Maybe it's a different plastic process or something. I'm sure yellow would be harder to spot anyway. Thanks.
-Josh
Old Jun 27, 2001 | 03:56 PM
RoostKing's Avatar
The blue plastic creases way to easily. No other color from yamaha does it. I have bent my red plastic plenty of times and still no creases. Im not sure why Yamaha has not fixed that problem, but then coming from the company that still uses the same chain adjustment/air box setups, I guess I'm not surprised.
RoostKing...
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
