warrior owners HELP!!!!!!
Old Jun 26, 2001 | 08:56 PM
tuckerabbott's Avatar
Ok guys and gals, here is the problem. I have a 92 warrior with about 60 hours on it. It ran great and i decided to do a thorough washing and tipped it back to rest on the grab bar and back wheels.
After that, it will start up and run great for about 3 minutes. I rebuilt the carb and adjusted the valves and I am still having same problem. It wants to cut out but stay running just not at mid and high rpm's. It always starts right back up just will not tach. I am at my wits end. Any suggestions will be greatly appreciated!
Old Jun 26, 2001 | 11:02 PM
CoalHillKing's Avatar
Ok man there are two things that i can figure might be wrong, you say it idles fine but cuts out mid range, check your parking brake, disconnect the sensor wires going into it, when the parking brake is in operation it trips the sensor and acts as a rev limiter on the engine, you may have gotten water or dirt or something in it so its like stuck on.......if that dosnt work check the ground wire/nut on your reverse, sometimes it loses good contact with the frame, when this happens your machine acts like it does in reverse with a rev limiter, good luck pal!!....let me know if this works!? [img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
