People say Blasters are tippy, is that true?
Old 07-06-2001, 09:49 PM
LiTtLeCaNaDiAnKiD's Avatar
Are Blasters so tippy that people hurt themselves a lot?
Old 07-06-2001, 11:18 PM
RdingManiac420's Avatar
Well many peaple do say that they are tippy due to there small wheelbase and width but I dont think they are at all. I can rail into and turn and it barely ever goes up on two wheeles.
Old 07-06-2001, 11:44 PM
brokemybanshee's Avatar
If you try ridig it like a big 4x4 or something (with little to no body english) You'll soon find yourself on your behind.. Ride it like its suposta be ridden, throw your weight around and you'll be all set. Stock, if you dont know how to throw your weight they can be tippy.. Aftermarket tires will help ALOT.
Old 07-06-2001, 11:56 PM
Rob4092's Avatar
My 11 year ole son has a 99 Blaster and yes, I was concerned that it seemed a little tippy. Even so, it is very simple to fix this.
First, take the front tires off and turn them around. Don't worry, regardless of what others say, this will not hurt the spindles. What is does do is make the front end 2" wider on each side (4" total). The air valves will now be on the inside, but they are still acessible to put air in them.
Next, go down to any ATV store and purchase spacers for the rear wheels. They run about $50.00 a pair.
With these two simple, inexpensive ($50 total) modifications, your Blaster will be unbelievably steady. This is a whole lot cheaper than putting extended a-arms and axle on it. The results will be the same, I assure you!
Good luck!
Old 07-07-2001, 12:16 AM
I shift my weight a lot on my Kodiak and fly around corners, but its both my dads and mine. So I'm buying a sport instead of owning a huge utility(can't do nothing on those).
shimanok2
01-29-2016 07:37 PM
Dunes and Dune Machines
09-29-2015 09:35 AM
Ahtatu
09-28-2015 12:14 PM
kbazzy
09-26-2015 11:26 AM
nastyblaster100
09-13-2015 01:19 PM
Quick Reply: People say Blasters are tippy, is that true?
